2003 g35 sedan starting issues after being ran.
Old Aug 13, 2016 | 02:54 AM
doranfreeman's Avatar
Angry 2003 g35 sedan starting issues after being ran.
Recently on my 2003 g35, ive been having issues with it starting after being ran for a decent amount of distance. about 20-30 minutes. First few times it happened, it throw up some check engine codes for knock sensor, cam shaft and crank shaft sensors. I have then replaced all of them along with a wire harness for the knock sensor but the issue still persist. I put the key in ignition and go to start, dashboard lights up, a/c runs, radio works, go to crank and it goes to turn over and dies off killing the lights with it until i stop turning the key. Get a whiff of smoke from under the hood as well, cant tell quite where its coming from. Any help would be appreciated!
Old Aug 13, 2016 | 07:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
Most important issue for you would be to find out where the smoke is coming from. When you replaced cam/crank sensors did you go with OEM parts or aftermarket? A lot of people have had issue with aftermarket parts.
Old Aug 16, 2016 | 11:04 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
First thing I'd be checking is engine grounds.
Old Aug 17, 2016 | 05:17 AM
telcoman's Avatar
Veteran: Army
Ever test your battery and how old is it?
Telcoman
VincenzG35
Mar 8, 2016 09:38 PM
Erika Espinosa
Feb 28, 2016 05:44 PM
itztwinki3
Feb 24, 2016 07:06 PM
co2guy
Feb 23, 2016 02:52 AM
