Does any one know what the differences are between the sedan and coupe oem thermostats? They have diff part numbers but look identical
Infiniti OEM G35 Thermostat 03-06 Sedan V35
Part #: 21200-31U1B
Infiniti OEM G35 Thermostat 03-07 Coupe V35
Part #: 21200-4W01B
Part #: 21200-31U1B
Part #: 21200-4W01B
telcoman
close
- Join DateMar 2011
- LocationCentral NJ
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideFront and rear cameras, tire pressure for all four tires can display on screen,folding side view mir
Liked:197 Times in 178 Posts
Have you tried asking the question at an Infiniti dealer parts department?
Might be worth a trip to meet the parts manager, service manager, and a few technicians that work on these vehicles daily
Telcoman
Telcoman
they are identical BUT the coupe opens at a different temp.
Its not super hard to do the research, i found it when i had to buy one. I THINK!!!! sedans are 180degrees and coupes are 170degrees. Dont quote it just stood out to me. I rolled with the standard for my car because the price was only a few $.
So in other words i can keep it cooler by running the tstat for the coupe?
Quote:
Not necessarily. Going to depend on other parts of the system such as radiator cooling capacity, fans, coolant condition, etc. Originally Posted by JZ
It may open sooner, but IIRC, they all seem to run around 200 degrees when at operating temp. You really don't want to run a modern fuel injected car much cooler than that anyway.
Agreed. Originally Posted by Mustang5L5
Not necessarily. Going to depend on other parts of the system such as radiator cooling capacity, fans, coolant condition, etc. It may open sooner, but IIRC, they all seem to run around 200 degrees when at operating temp. You really don't want to run a modern fuel injected car much cooler than that anyway.
Also if you do any of the research and homework i did about the T-stats, you will also find out that 350z/G coupes cooling systems run at a slightly higher pressure 1.1 bars VS .9 bars or w/e units they use. Again this is from memory when i did the actual homework about the T-stats and cooling system.
Its all out there or look at a coupe and sedan FSM. Stick with the stock is the best unless you have a reason not to because its not "better"
- FS[SoEast]: OEM 17" wheels with 225/55/17 Blizzaks
- FS: 2007 G35s Sedan 6spd MT - Chicago
- FS[Canada]: 2006 g35 black sedan 6MT, TORONTO
- OEM Tire Size
