Windshield wipers don't work
Old Jun 18, 2017 | 11:07 PM
g35lyfe's Avatar
I own a G35 coupe from the year 2004. I recently had an electrical problem that caused one of my headlights to not work, after messing around with different techniques, I finally sound the solution. The reason I mention this is because I took out my fuse box and replaced certain fuses and when I turned on my car my wipers would not work. I also tested the voltage of electrical parts of my car using some tool to detect how much power is being drawn. Now I brought it to a mechanic and he directed me to an electrician, the electrician recommended a BCM replacement. I went to the dealer, had it replaced and still no working wipers. I bought a wiper motor, installed it myself, and still no working wipers. I'm extremely frustrated and have no idea what could possibly be the problem, and so many so called "'experts" can't solve the problem either. Please help me, I'm fed up.
Old Jun 19, 2017 | 12:36 AM
coffeysm's Avatar
I would like for an electrcial diagram and go from there. Check the fuses, relays, and things like that. Another thing to consider is the linkage. Nit sure about Infiniti when this happened on my Audi. I had to remove the linkage, torch it apart, regrease, and assemble. They are known for rusting in place.
Old Jun 19, 2017 | 07:24 AM
telcoman's Avatar
Veteran: Army
First of all when you as an amateur start replacing parts without knowing exactly what you are doing you are masking the original problem making troubleshooting much more difficult.
Who replaced the BCM? You or the dealer?
Why didn't you just tell the dealer to just fix the wipers without telling the dealer the BCM needed replacement?
Perhaps the problem is a loose/bad wiring harness connection so you can replace all the parts you want and still not solve the problem.
You can start by reading/following the troubleshooting steps in the FSM
http://www.nicoclub.com/service-manu.../Coupe/2004/ww
System Description
AKS009YD
All front wiper relays (HI, LO) are included in IPDM E/R (intelligent power distribution module engine
room).
Wiper switch (combination switch) is composed of a combination of 5 output terminals and 5 input termi-
nals. Terminal combination status is read by BCM when switch is turned ON.
BCM (body control module) controls front wiper LO, HI, and INT (intermittent) operation.
IPDM E/R (intelligent power distribution module engine room) operates wiper motor according to CAN
communication signals from BCM (body control module).
Power is supplied at all times
through 50 A fusible link (letter F, located in fusible link block)
to BCM (body control module) terminal 55
through 10 A fuse [No. 18, located in fuse block (J/B)]
to BCM (body control module) terminal 42
through 20 A fuse [No. 73, located in IPDM E/R (intelligent power distribution module engine room)]
to front wiper relay [located in IPDM E/R (intelligent power distribution module engine room)]
through 15 A fuse [No. 78, located in IPDM E/R (intelligent power distribution module engine room)]
to CPU (central processing unit) [located in IPDM E/R (intelligent power distribution module engine room)]
through 10 A fuse [No. 71, located in IPDM E/R (intelligent power distribution module engine room)]
room
When the ignition switch ON or START position, power is supplied
through 10 A fuse [No. 1, located in fuse block (J/B)]
to BCM (body control module) terminal 38
through ignition relay [located in IPDM E/R (intelligent power distribution module engine room)]
to front wiper relay [located in IPDM E/R (intelligent power distribution module engine room)] and
to front wiper high relay [located in IPDM E/R (intelligent power distribution module engine room)]
through 10 A fuse [No. 84, located in IPDM E/R (intelligent power distribution module engine room)] and
through IPDM E/R (intelligent power distribution module engine room) terminal 44
to front washer motor terminal 2.
Ground is supplied
to BCM (body control module) terminal 52
through grounds M30 and M66,
to IPDM E/R (intelligent power distribution module engine room) terminals 38 and 60
through grounds E17and E43,
to combination switch (wiper switch) terminal 12
Go grab your multi-meter
Good luck
Telcoman
sonicvirus
Nov 29, 2016 07:37 PM
DKnibb
Dec 20, 2006 12:50 AM
DKnibb
May 26, 2005 09:46 AM
BillR
Jun 7, 2003 09:44 AM
