My speedometer
Old Nov 21, 2017 | 08:55 AM
mdmurphy0421's Avatar
My speedometer
My speedometer isn't working, Do I need to take to dealer or can I take to local mechanic? 2004 sedan g35
Old Nov 21, 2017 | 07:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There's a few components, the speed sensors are located at the rear differential, it's a magneto-pickup style, I would have it inspected for damage first to make sure something isn't visibly damaged. The combination meter can fail also though, the easiest way to check would be to use an OBD2 scanner to see what speed the computer is sending while you drive. If the computer is reading the right speed then it's likely the combination meter, if the computer doesn't show you moving then it's probably something with the speed sensors on the diff.
zachdillon
Nov 20, 2017 04:56 AM
gege
Oct 8, 2017 01:56 PM
Serge Mullen
Sep 2, 2017 01:01 PM
guitarrocker98
Interior
11
Apr 13, 2017 01:01 PM
wreck
Jul 3, 2003 07:37 PM
