3rd brake light removal on a 2005 g-35 sedan.
Old Feb 24, 2018 | 11:51 AM
G35 Dan's Avatar
how do I remove the 3rd break light via the trunk? how do you access the second screw?
Old Feb 24, 2018 | 05:45 PM
05_SkylineSedan's Avatar
20 Year Member
If I remember correctly, you can only almost get to it from the trunk. Service manual:
http://www.nicoclub.com/manuals/G35/...5_Sedan/lt.pdf
(p137)
says to remove the rear parcel shelf:
http://www.nicoclub.com/manuals/G35/...5_Sedan/ei.pdf
(p41)
But that means you have to start by removing the rear seat, seat belt anchors, etc...
Then finally you get to remove the two screws holding the center brake light...
Old Feb 24, 2018 | 06:09 PM
theronz's Avatar
Drill a hole in the sheet-metal so you can get a screwdriver on it.
It's a very tight squeeze figuring out how to wiggle the bulb out and back in but it will fit.
Just pay attention to the wire routing and don't put the new one in backwards/upside down.
Where did get it and what new bulb are you putting in?
I've had this one for 2yrs with no problems.
https://www.ebay.com/itm/22267516653...m=222675166535
Old Feb 24, 2018 | 07:46 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I just moved mine back and forth until the tab broke off, pulled out the old light, put in the new, tightened down the one screw. Stays in place, works fine. Took me 5 minutes total.
jimborusk13
Interior
20
Oct 10, 2018 10:37 AM
underworld
Jan 7, 2018 08:47 PM
rdbusnret
Dec 7, 2017 06:49 AM
John White
Dec 1, 2017 08:28 AM
