Transmission differences
Old Jun 21, 2018 | 08:40 AM
IvyG35's Avatar
Question Transmission differences
Hey guys,
I looked around but couldn't find anything on this topic (if i missed a thread that anyone knows of, can u drop the link below??). I have a 2003 AT, and i am wondering which AT will be a direct replacement to mine. I will need a new tranny soon, but there seems to be different variations depending on the year. If anyone has some advice please let me know!!
Old Jun 23, 2018 | 03:57 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You need to pull off the panel in the passenger seat area and find out if you have the external TCM, you should be able to use any G35 transmission but there was a major revision that decided where the TCM was installed. Keep in mind that either style will work it just depends on if you are capable of swapping out the valve body and harnesses to match what you need.
You probably have the 3 green harnesses on your transmission if so just get another one that looks physically the same and ignore all the various component revisions because there's "technically" like 25 different transmissions for the G35 if you count every revision type. Most of that crap was changing vendors for the solenoids, gears, screws, etc but they all perform the same mechanically and are all physically interchangeable between 2003 and 2006 but the internal vs. external TCM is the only MAJOR difference that would prevent you from doing a direct bolt-on swap.
Old Jun 24, 2018 | 11:10 AM
IvyG35's Avatar
Okay that helps a lot, Thanks!!
Old Apr 19, 2021 | 12:24 AM
Carlos Batres's Avatar
g35 at
Tcm compatibility
Do you know the compatibility for the valve bodys bewteen the years? I recently swapped an 04 sedan g35 to a 06 coupe but it seems like the computer is not responding. Need some help please
Old Apr 19, 2021 | 07:01 PM
cleric670's Avatar
BANNED!!!
Shouldn't be an issue, what's it doing (or not doing).
Old Apr 19, 2021 | 08:09 PM
g35 at
The issue is the car is not responding once in drive and very slow response in neutral. Already changed the throttle body and Maf sensor but the car remains the same. Seems the car is limp mode but already tried everything to take it off so now I’m thinking it can be the tcm not matching with the ecm.
Old Apr 19, 2021 | 09:08 PM
cleric670's Avatar
BANNED!!!
Is it throwing any codes when you plug in an OBD2 scanner?
Old Apr 19, 2021 | 09:45 PM
g35 at
It was just throwing me P0300 AND P0102.
Old Apr 20, 2021 | 10:37 PM
cleric670's Avatar
BANNED!!!
P0300 random misfire, start by inspecting the plugs, including looking for oil in the spark plug well tubes.
P0102 Mass airflow sensor, this will absolutely limp mode the car and is probably why it's misbehaving. Inspect the harness but it's probably a failed MAF.
Ami Svg
Sep 3, 2021 06:14 PM
dacrew4009
Drivetrain
Jul 23, 2018 08:01 PM
xtremetrans
Drivetrain
Sep 25, 2010 09:30 AM
S14Jimmy
Drivetrain
25
Jun 13, 2006 09:28 PM
Skeeter
Drivetrain
Apr 1, 2005 09:44 PM
