2003.5 Sedan Safe Mode, rough idle, etc. saga...
Old Jul 29, 2018 | 01:58 PM
Learned Hand's Avatar
My car sat for about a year after it developed a really rough idle and started dying at low speed/rpms. 178k miles on the car. I recently tackled it, replacing the battery (it was dead of course), and the spark plugs. That didn't fix the issue, it still likes to die when i start it and I believe it is in safe mode, as the RPMs won't go above 2k. The dash is showing the SLIP, CHECK ENGINE SOON, and VDC OFF lights. So I took it to the stealership and they pulled the following codes:
P0101 MAF SEN/CIRCUIT
P0103 MAF SEN/CIRCUIT
P0113 MAF IAT SEN/CIRCUIT
They wanted almost a thousand bucks to replace the MAF sensor. I told them nah and took the car home, pulled the MAF sensor and cleaned it. This did not fix the problem. Before I go out and buy a MAF sensor and go down that road, is there anything anyone else can think of that I am missing here? I did not do any of the ecm/electrical resets I have seen, where you stop the pedal five times in five seconds, etc. Should I try this or just go out and get a MAF sensor?
Old Jul 29, 2018 | 05:03 PM
telcoman's Avatar
Veteran: Army
Don't use non OEM parts
Telcoman
Old Jul 29, 2018 | 06:49 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The MAF sensor is one of the few sensors that I will buy aftermarket but check online, you can get the OEM Hitachi MAF0031 which is JUST the sensor for about $50. If you cracked the MAF housing then order MAF0029 which has the sensor and the housing.
Old Jul 30, 2018 | 03:48 PM
Where are you seeing it for $50? I haven't checked my housing, but when I pulled the MAF and cleaned it, the electrode looking sensor didn't look damaged or even dirty really.
Old Jul 30, 2018 | 05:32 PM
cleric670's Avatar
BANNED!!!
When they're toast they look exactly the same, the damage isn't something you will ever see.
There's a $48 one on eBay, use Google to search the part number.
Old Jul 31, 2018 | 02:21 PM
Awesome, thank you very much.
Old Jul 31, 2018 | 02:51 PM
Telcoman
Do you know who makes the OEM part? I am finding HItachi and Duralast MAF sensors...
Old Jul 31, 2018 | 05:26 PM
Blue Dream's Avatar
I drove ttrank's car solo
I was feeling a little mischievous: http://lmgtfy.com/?iie=1&q=Who+manuf...03.5+G35+sedan
Delphi is the correct answer......
Old Jul 31, 2018 | 05:37 PM
cleric670's Avatar
BANNED!!!
Huge difference between an actual OEM part and one build to "OEM spec".
Just because it fits doesn't mean it's the same.
Old Aug 4, 2018 | 08:50 PM
Final follow up on this one, I bought a replacement MAF, threw it in myself, and did the ECM reset procedure. Fixed the car and cost me about $200. Stealership wanted over $900 to do this work.
Old Aug 4, 2018 | 08:54 PM
cleric670's Avatar
BANNED!!!
Awesome., glad everything worked out.
TreeFiddyGT
Jan 20, 2015 09:29 AM
Schuma3955
Jan 26, 2012 06:03 PM
G352NV
Picture Share
44
Sep 10, 2006 06:13 AM
