car won't start
Old Aug 15, 2018 | 03:29 PM
Aliv36's Avatar
car won't start
i own a g35s (manuel if that matters).
Every time i start my car from a cold start the car starts. however whenever i try to start the car while the engine is still warm the engine doesnt wanna turn over, all the lights on my dash and interior turn as well as the headlights and tail lights.
any idea as to why this is happening ( my battery was replaced not too long ago, and my key fod is a little bit old however the car still reads it).
Old Aug 15, 2018 | 03:50 PM
MooseLucifer's Avatar
5 Year Member
blk
What happens when you turn the key, car cranks strong but doesnt fire? Car cranks weak? No crank at all, if so does it click? How long does it take to start when cold? Do you have any check engine codes? What year / how many miles?
Read though any of the threads listed here.
Old Aug 15, 2018 | 05:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like a bad starter solenoid, fail to start when hot issued are usually that. Hard to bench test because by the time you get it off it's cooled down enough and starts again.
Old Aug 15, 2018 | 05:33 PM
telcoman's Avatar
Veteran: Army
Are you getting spark?
Have you checked for fuel pump pressure
Have you tested your battery, cables, tightness of battery posts, ground connections?
Clutch interlock switch?
whenever i try to start the car while the engine is still warm the engine doesnt wanna turn over, ).
If you are saying the starter will not operate there are a couple of starter relays in the IPDM
Test them
Telcoman
dsheldon924
Jun 27, 2017 07:26 PM
sman217
Intake & Exhaust
12
Dec 18, 2016 07:02 PM
Lord Trazaza
Nov 14, 2016 12:42 PM
b_dupy
Oct 12, 2016 09:04 AM
DaveActiveTuning
Feb 12, 2008 09:33 PM
