Alarm (Panic Mode) Keeps Going Off Randomly
Received 2,462 Likes
on
Coupe 6MT Premium RAS
I took that apart yesterday and it appeared to be fine, the IPDM itself was dry and there was no corrosion. I dusted the IPDM because it was a tad dusty, but I have seen dustier boards in computers that run with no issue. I sealed the box up tight so no water should be getting into it unless there is standing water. When I took the IPDM out of the battery compartment where it sits, it had about 1/4 inch of water because the drain plug was plugged up. I cleaned it out and dried the compartment up, so there would be no more standing water. I don't know that it would be the issue after doing all of that. I will probably go pick another IPDM up on the weekend from a local salvage yard just to try it though.
on
gq916
08-08-2016 05:50 PM
