Po3000 misfire headache
Old Oct 10, 2018 | 12:09 PM
Cabos G35 Coupe's Avatar
I have 2005 g35x sedan with random po300 misfire. Car drives perfectly drive and idles great. Would spark plug or ignition coils still be the problem even if drives normal? Any recommendations please would help
Old Oct 10, 2018 | 12:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
When did you last change plugs, what procedure did you use to test the coil packs, is there oil in the spark plugs wells?
Old Oct 10, 2018 | 08:28 PM
i have ave to change the topic now. I fixed the misfire which was a crack on the stock intake. Now I have a p1273 and p1283 which are the air fuel sensors on both cats I replaced those last month. But I’m reading now that it needs a relearn when you replace those air fuel sensors
NISMOTO
Sep 5, 2008 03:41 AM
cochinogato
Dec 2, 2006 10:36 PM
vengeqi
May 7, 2006 06:02 PM
