my "new" 2003 G35...and questions
Old Nov 4, 2018 | 10:17 PM
johndom450's Avatar
My guess is at the HVAC unit too. I'd check all the pins on the connector and then look at the back to make sure the wires weren't pulled out of it at all when switching head units. If those are all fine, you could check further downstream to see if the wires have been pinched or frayed at any point.
​​​​​​Electrical problems are always tricky, but it sounds like you have a good handle on this. I'll be following this thread to find out what the true cause is!
Old Jul 20, 2019 | 06:47 PM
Neco's Avatar
G35 sedan
Originally Posted by mjoc13
5) when i start the car or drive up to 20km/hr the cooling fans seem fully engaged and very loud (like i'm driving a 1 ton). From my reading, these are mechanical fans, and i'm checking the clutch unit; however, how easy should i be able to spin the fan with the car off?
Did you ever figure this problem out?
Old Jul 27, 2019 | 06:57 PM
mjoc13's Avatar
03 Sedan
fan clutch replaced, sadly no difference - will just have to live with the crappy loud fan...
Some people have swapped to an elec fan, something i won't do.
Hypnopirate
May 1, 2018 01:52 PM
GAWD
Aug 4, 2017 11:21 PM
nevets11_2003
May 5, 2010 03:11 PM
G Fun
Apr 14, 2005 10:11 AM
