having gas gauge problems
Old Oct 21, 2018 | 01:06 PM
domvill96's Avatar
Infiniti G35x
I have a 2005 infiniti g35x sedan. my gas gauge has been reading full since I bought it with the check engine light on, I replaced the driver side float hoping it would be the easier one but I was wrong. my emissions is due so I replaced the passenger side float, fuel pump and strainer. still no luck still reading the tank is full with same code, where the heck do I go from here
Old Oct 21, 2018 | 01:29 PM
telcoman's Avatar
Veteran: Army
Follow the troubleshooting steps in the FSM
Telcoman
Old Oct 21, 2018 | 08:28 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
https://www.nicoclub.com/FSM/G35/Sedan/2005_G35_Sedan/
Section DI somewhere around page 18 shows the steps for testing resistance to verify the float is sending the correct signal, also do the DIAGNOSTIC MODE to make sure the needles physically move.
If the sender is outputting the correct resistance values then your combination meter is probably fried, this is VERY common btw.
Old Oct 25, 2018 | 06:33 PM
g35racing's Avatar
i have the same problem
Old Oct 25, 2018 | 09:02 PM
Blue Dream's Avatar
I drove ttrank's car solo
And you've been given the way to diagnose it and potentially fix it above. GL
ttrank
Sep 10, 2018 07:58 AM
Calipat916
Sep 29, 2016 01:29 PM
Muschong
Aug 4, 2016 03:43 PM
