Should I worry about this?
Old Oct 21, 2018 | 11:22 PM
Ichiglo_'s Avatar
So I took my car to my buddy to install some tie rods and an awful accidental happened.while he was about to finish the jack slipped from the front of the car because of the floor surface and the car fell and popped my radiator up and cracked my radiator bottom support and my car leaked coolant.My buddy bought a new radiator and fixed the problem and all and my car is good now it doesn’t overheat or anything and my ac blows cold and heat is good but it’s currently being hold up by zip ties smh.Anyways I learned my lesson and will no longer be taking my car to him but I’m wondering is this gonna cause a problem down the road or should I buy a new rad support? Again please don’t flame me I learned my lesson and will no longer take my car to him
Old Oct 21, 2018 | 11:52 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I can't see the photo it's a black image but from what you said it's probably a bent front member which is a replaceable component. Yes you need to fix it because tie wraps will get brittle and crack, yes they'll work in the short term if they are good quality ones like for HVAC duct.
Never go back to that guy, sounds like he doesn't even know where the correct lift points are located which is the first thing to know, if you don't have that mastered you'll probably fail at everything else as well.
Old Oct 21, 2018 | 11:59 PM
Ichiglo_'s Avatar
yea I figured especially since I’m in the Midwest and snow is coming and my rad support might plow through snow and destroy the zip ties and yeah I learned my lesson
Old Oct 22, 2018 | 11:46 AM
Urbanengineer's Avatar
Anyone who doesn't use jack stands with a hydraulic lifter imo is insane. A car will fall and KILL you. People surprise me.
Old Oct 22, 2018 | 01:04 PM
cleric670's Avatar
BANNED!!!
My guess is it happened while lifting the vehicle to set it on the jackstands, that dimple on the crossmember for the service jack is fairly small and with a large shoe on the service jack I can see how it would happen if you didn't look exactly at what you were doing. When I use the large shoe I always try to get the ridges on it behind those two mounting bolts next to the dimple so it can't slide.
Using the smaller shoe it's never an issue.
stoofpilot
Aug 23, 2009 05:20 PM
LazyAlex
May 29, 2009 12:00 PM
johnsonhuang
11
Sep 10, 2007 01:36 PM
nalinc23
Nov 21, 2006 01:15 PM
ScapGF
Feb 22, 2006 09:14 PM
