Should I worry about RATTLES from system install?
Should I worry about RATTLES related to system install?
Tomorrow I am getting 2 10in DA subs installed as well as replacing the components with DA661's.
Now, should I expect a decent amount of rattling from the trunk, doors, etc...?
If so, how much?
Can it be prevented?
What should I expect?
If so, how much?
Originally Posted by MikeyMike
You're going to have to Dynamat the hell out of you trunk...and don't forget to put some foam where the rear deck meets the trunk.
ENVautoDetailing.com
If i were you i'd get a dynamat extreme bulk pack. Then lay it out over your whole trunk. I'm doing the same thing to my sedan when i put in my 2 12" alphasonik's. good luck
-GP-
-GP-
Do the best you can ahead of time with dynamat, but the rest you will have to work out as they show up. As the car gets older you will get more rattles.
You can shim the problem areas with rubber and foam tape.
Just got the car back from the install place. Luckily the trunk rattle really isn' that bad. I will probably dynamat the trunk at some point, but for now it isn't high on my list of priorities. But, I DID go ahead and have the doors completely covered in dynamat, making the DA661s I put in there sound great!
Get Cascade VMAX. You can buy a bulk pack for a really good price by following the llink on their website. Don't buy it from a dealer, they make a fortune on this stuff!
sclair
13
Aug 7, 2015 05:43 PM
