06 G35X right front bottoming out
Old Nov 11, 2018 | 11:29 AM
lrodptl's Avatar
Right front wheel side is loose or bottoming out/bumpy while driving. I changed the struts,sway bar link and CV half shaft due to torn boot and it's the same. Any thoughts on where to start?
Old Nov 11, 2018 | 11:52 AM
cswlightning's Avatar
Rebuild the front suspension with poly bushings, you've probably got a bad bushing or a bad ball joint or maybe both.
Old Nov 11, 2018 | 03:29 PM
lrodptl's Avatar
Any links here for replacement?
Old Nov 28, 2018 | 09:50 AM
lrodptl's Avatar
Turned out to be the compression rod
Old Nov 28, 2018 | 07:55 PM
Glad you found it! Compression rod bushings and ball joints are a common failure mode as well as the rest of the stock rubber bushings.
m35steve
Jun 1, 2011 11:05 PM
ash1707
Apr 28, 2011 06:04 PM
MANSU_V36
V36 Brakes, Suspension, Wheels & Tires
Sep 15, 2010 04:43 PM
G35driver123
Oct 6, 2008 10:00 PM
S 854
Jun 11, 2008 07:58 PM
