Is my G gone?
Is my G gone?
Yesterday night as I was getting out of work I notice my car (AT) transmission would not accelerate on park or reverse.you really needed to step on it for it to move a little bit but then you lost control.As I left out of my parking spot I notice I huge puddle of what seems to be either trans oil or motor oil.I recently got my trans oil changed last week when I installed my new radiator so Im blaming it on that.Anyways is my car done for or is there hope?
Probably not
Unless you noticed problems before then it's not likely your trans is bad, yet. You need to check your transmission oil dipstick. Get the car to operating temp, switch through each gear, then check it with car running. If it's low then there's probably not enough pressure to switch gears properly
Take it back to the mechanic who changed the radiator, because the two are probably related
It's possible the cooler lines that attach to the radiator blew off. I would check the lines on the bottom before you start the car again; I wouldn't even turn it on without doing that first. If they look all wet and leaking; I would call the shop and try to get them to have it towed. Make you sure use Nissan compatible fluid; I like Idemitsu Type J, however, I've used Valvonine Maxlife ATF in my other cars as well with success. I believe the Valvoline is Nissan compatible as well.
PSA buy towing through AAA or Good Sam Roadside. You can't be risking your car in moments like these. They will tow your car to the closest capable mechanic... and you can always make an argument for your own mech.
thank you guys turns out it was my trans cooler line on my radiator that popped.
Did the shop handle it or say "what a coincidence?". I'd also ask them what type of fluid they put in...
the shop wasnt picking up their phone so I went to another reputable shop around my area and they were really nice and shamed the previous mechanic who installed my radiator lol
That happened to my son's BMW about 4-5 weeks after a new motor was put in.
Knew it would be the trans cooler line; my car had the exact same leak just after an entire transmission install. Seems to be a common problem to not attach them correctly/test them at all.
The shop that initially installed needs to take the hit for that, that could've easily caused some huge damage.
