Dented camshaft position sensor?
Old Jan 6, 2019 | 11:01 PM
Timepolice's Avatar
Pulled out my old camshaft position sensor (bank 2) after pulling the p0345 code.
Replaced the old with a new OEM one from Infiniti (a new design, the shaft is metal and has different measurements).
Started the car up and it had a long hard start with the slip, vdc and see lights on. Figured it take the sensor out and check if anything was blatantly wrong with how I installed it...and turns out it was dented??? This 100% happened while it was in the engine.
My question is what the hell happened to it?? The new sensor is a bit wider than the old one and the dent is literally right where the new sensor gets a bit thicker...it's like the sensor is too thick for the cam to pass? This is the part they gave me and it matches everything I've found online.
What exactly is going on here? Why doesn't seem like the new sensor doesn't fit? Even the bolt that locks it in wouldnt lock in, I was able to continually "tighten" it past where I was able to tighten the old sensor.
Please, input here would be greatly appreciated.
Thanks
Old Jan 7, 2019 | 03:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
What's the part number you installed, should be either
23731-6J90D
cleric670's Avatar
BANNED!!!
Or
23731-AL61D
Old Jan 8, 2019 | 03:55 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I had both Nissan revised cam sensors on my desk brand new in the bag and measured them. Even if you swapped them from side to side it shouldn't contact the cam since they are the exact same length. I have no idea why one would get dented without dropping one.
Old Jan 8, 2019 | 05:41 PM
cleric670's Avatar
BANNED!!!
I suspect he was sold the wrong sensor.
Charshycs
Aug 5, 2017 08:00 AM
Mr. Uy
41
Feb 3, 2016 06:58 PM
MIA Philly
Apr 13, 2011 09:14 PM
suby01
Sep 3, 2008 05:55 PM
monkeywinky
May 10, 2008 10:05 PM
