04 G35 Sedan Codes
Old Jan 11, 2019 | 11:11 PM
MichaelW3131's Avatar
g35 sedan
04 G35 Sedan Codes
So I met this guy to buy his 2004 g35 sedan, but it had a “service engine soon” light that went on and off throughout the day, so we scanned it. These are the codes that popped up (in the picture). He then ordered a new wire harness to fix the issue. I’m curious as to how common these codes are, what the fix may be, and how big of a deal they are? Thank you for any help!
Old Jan 12, 2019 | 12:22 AM
g35 sedan
Old Jan 12, 2019 | 04:06 AM
hennessy45's Avatar
I have 2003 G35, and there no issue with the knock sensor yet, there few video on youtube show how to replace wire harness, good luck
Old Jan 12, 2019 | 11:06 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The knock sensor code is almost always the sub harness, some folks have managed to change it out without disassembling the intake but the normal process is to remove the upper/lower plenums and the collecter intake at the bottom. Then swap the sub-harness (since you have it all apart you should just replace the entire sensor as well since it's a $20 part that probably has 100k+ miles on it). Then reassemble, it's not HARD to replace but it's a lot of little bolts and you need to follow the FSM for proper torque and pattern. If you aren't the type to actually follow the manual or torque fasteners I would opt for the other method because you will probably just screw something up.
The lean bank 1 code however could be a number of different things ranging from failed O2 sensor to failed fuel dampers to bad spark plugs to intake leaks, etc. Expect quite a bit of troubleshooting to find the actual issue.
I would consider a vehicle like that to be sold as a "mechanics special" and have a cost reduced by -30% due to the amount of labor needed to fix the problem.
If you know how to troubleshoot engine problems like this and will do the work yourself it's not a problem, if you don't know how or will be paying a shop to do the work then just walk away now because it will easily be $1k to fix those problems.
Old Jan 23, 2019 | 10:53 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Don't rule out the knock sensor until it's tested. Some models have more trouble than others with the knock sensor itself. Example is the G20, The 2000 and up almost never have a knock sensor failure but the 1999 down models fail all of the time. I don't know if it's how the knock sensors are driven from the ECU or if it's just certain types that fail more often but they do fail. The G35 sensors may be more reliable since they are slightly newer. Please report back what you find, I would be interested in hearing what the failure is/was. If it is the harness I would like to know what failed. Does the crimped pins come apart over time? Oil/contamination get into the connectors?
Old Jan 23, 2019 | 03:07 PM
cleric670's Avatar
BANNED!!!
The ones that have a sub harness problem usually have brittle and cracked insulation on the wires that eventually rot away or end up making contact with each other.
sinnistar
11
Sep 9, 2019 12:56 AM
noorkhan92
Jan 18, 2018 12:12 PM
ojra89
V36 Engine, Exhaust, Drivetrain & FI
Sep 25, 2016 07:38 AM
shauno
Jan 21, 2014 09:36 PM
numair
Mar 31, 2010 12:06 AM
