I need some help guys 06 G35 running real bad
Old Mar 1, 2019 | 12:41 AM
Tastywaves's Avatar
06 G35X, Lighter blue model
Hello guys thanx for having me I'm so distraught because I bought this car from the small dealership locally the check engine light came on immediately the car started running bad I plugged it up and it ran out crankshaft position sensor so I replaced it and still doing the same thing and it’s running even worse now. Lately it’s running as if the plugs were fouled out. So I replaced the plugs with OE plugs and it still running terrible. Has anyone else had the same type issue because I could really use some help?
I can be reached at 1-443/453/2942. Thanx in advance.
Ps. I love this car so much and if I can get this fixed she'll last a long time
Old Mar 1, 2019 | 02:14 AM
Scorpi0's Avatar
Is it throwing any other codes?
Old Mar 1, 2019 | 07:25 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Did you use cheap cam sensors? I had trouble with mine when I first bought it and went through 2 sets of cheap cam sensors until I broke down and bought OEM ones from the dealership. I have a thread on here with the factory part numbers if you need.
Old Mar 1, 2019 | 09:10 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Hitachi or OEM sensors only, aftermarket ones are notorious for not working.
Old Mar 1, 2019 | 11:58 AM
Tastywaves's Avatar
Troubled car
Hey guys yes thank you for your response. The first crankshaft position sensor that I bought was from Advanced auto that one did not Cure the issue. I took the car back to the place that I bought it from let them try and fix it they stated to me that they used an OE Crankshaft censor and still did not work. It’s strange that I cannot figure out why when I turn a corner and takeoff from a stop at times I get that to second hesitation as if I’m in neutral and then it kicks in. And if I smash the gas to the floor the car bogs down really bad and falls on its face and then it picks up and falls again.
Old Mar 1, 2019 | 12:14 PM
cleric670's Avatar
BANNED!!!
Sounds like a huge vacuum leak, get an OBD2 scanner that does real-time data and watch the short term fuel trim.
Old Mar 5, 2019 | 04:05 PM
Tastywaves's Avatar
Hey buddy do you know where I could get that done at? Is this something that the auto parts store can do or check for me or do I need to take it to a shop for that?
Old Mar 5, 2019 | 06:22 PM
jbarnett250's Avatar
really inexpensive (~$15) bluetooth obd readers will connect to your phone and can do a decent job of data logging a few sensors at a time with a free app. you can log more sensors if you buy an obd app for the phone. you want to log the data while you're driving. but i have that and can see the traces but still don't know exactly why my cel is on.....
Old Mar 6, 2019 | 09:39 AM
Tastywaves's Avatar
So do I just plug that up to the computer for the car and then read it off the app?
Old Mar 6, 2019 | 11:28 AM
cleric670's Avatar
BANNED!!!
Torque Pro for Android is the one I use. Works good, you should just take the intake pipe off and inspect it for cracks in the accordion section, check the PCV hoses, etc. Sometimes that stuff is pretty obvious.
jonny917
May 21, 2006 07:59 PM
SteveAreno
Nov 7, 2004 01:47 AM
SteveAreno
Southern California
Oct 28, 2004 03:11 AM
