Hissing sound when pressing on brakes
Old Apr 24, 2019 | 03:53 PM
Alex R's Avatar
Recently noticed a hissing sound when pressing on the brakes. I looked it up and was thinking that maybe it’s the brake booster but everything is normal other than the sound. Brakes are working perfectly, pedal is normal, stopping distance is normal. There are no signs other than the hissing sound. It sounds like air is being released, I’m not sure if this is a cause for concern. The brake fluid is is also normal and not draining or anything. Any ideas?
Old Apr 24, 2019 | 04:48 PM
christopherv5's Avatar
It's normal. Depending on the pads, some are louder than others. It's just the friction
Old Apr 24, 2019 | 04:55 PM
Alex R's Avatar
when I look up the problem it says that it’s the brake booster, I’m worried that it could be that and I’d have to replace it.
Old Apr 24, 2019 | 05:02 PM
Alex R's Avatar
you don't think that it could be the brake booster? If it's just a normal sound from the pads I would be very relieved. I'm just not sure because the brakes are operating perfectly other than the hissing/air sound...
Old Apr 24, 2019 | 05:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it makes the same sound when you.press the brakes WHILE STOPPED then you.have a failing brake booster. If it only makes the sound while moving then it's probably just the brake pads.
Old Apr 24, 2019 | 05:42 PM
Alex R's Avatar
Yes it only makes the sound while pressing the brakes when I'm driving. If I'm going very slow I don't hear the hissing. I have gotten new brake pads and rotors recently (within last few thousand miles). So you think its just nothing to worry about?
Old Apr 24, 2019 | 07:09 PM
Blue Dream's Avatar
I drove ttrank's car solo
Don't worry be happy.
Old Apr 28, 2019 | 10:11 AM
coffeysm's Avatar
I'd say it's normal and you if you did have to replace it there is not much to it. You can get a used one for like 50 bucks and a new o-ring from the dealer is like 15.
Andy.
Jul 13, 2017 05:46 PM
mikeee2
May 11, 2009 09:55 PM
chinfiniti
Jan 7, 2006 07:04 PM
Drewer
Drivetrain
May 6, 2004 05:03 PM
hellsfire119
Oct 8, 2003 11:50 AM
