Transmission swap
Old Apr 29, 2019 | 12:11 AM
AudioBoss's Avatar
Infinity g35 sedan automatic
Transmission swap
I have an 04 get transmission I want to swap into my 03 get, Infinity said I was comparable, I told them the vin #'s but the plugs for the wiring harness are different is there a way around it?
Old Apr 29, 2019 | 10:59 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
If it's an automatic you will probably need to swap the valve body.
Old Apr 29, 2019 | 02:10 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Keep the existing valve body/tcm/harness. It's easy to swap them to the new transmission, look up the instructions for a transgo shift kit and you'll find good pictures for how it comes apart. Don't tear the wiring harness grommet, there's a snap ring to remove to get the plug to disengage I think. Make sure you get all the wires routed back through the little metal keepers on the inside, I STRONGLY recommend taking good pictures to refer back to.
SuprachargedG35
Drivetrain
Feb 14, 2018 10:52 AM
aznx2cool4u
Drivetrain
29
Mar 28, 2010 06:02 PM
fxg
Oct 9, 2006 02:15 AM
KaosKlique11
Drivetrain
Sep 10, 2006 09:16 PM
sushmaster_g35
Drivetrain
Feb 24, 2005 09:50 PM
