Leaking Valve Cover
Old May 18, 2019 | 01:51 PM
SoInG's Avatar
G35 Base Sedan/No mods
Leaking Valve Cover
2004 G35 Sedan. About 2 months ago, I took the upper plenum, fuel rails, etc. off to replace a knock sensor and harness. While I was in there, I noticed some oil in a couple of spark plug tubes, so I ordered new valve covers. Put the new valve covers on, torqued bolts in order and to spec, and put everything back together. All has seemed fine up to now. Occasional check for leakage and did not see any. Until today, when I crawled under the car to do a drain and fill of the transmission fluid. There is oil leaking on the driver side, looks like from the back side of the valve cover. Not enough to drip on the ground, but enough to get oil on areas underneath. Is there any remedy here or do I have to take it all apart again and, possibly, put another new cover or gasket on?
Thanks
Old May 18, 2019 | 01:59 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Another gasket, did you use any RTV on the corners? The FSM only specifies it in the front corners but I like to apply a little to the entire gasket.
cleric670's Avatar
BANNED!!!
Verify it's not coming out of the cam position sensors though.
Old May 18, 2019 | 02:02 PM
SoInG's Avatar
I used RTV on the front corners per the manual, but did not apply any to the rear. Good point on the cam position sensor. I just got a code on the one on the driver side a few weeks ago and replaced it. If it is leaking, can I put anything on it? It just screws down with one bolt.
Old May 18, 2019 | 02:04 PM
cleric670's Avatar
BANNED!!!
The only thing you can do is inspect the o-ring for any rips/tears and replace it as needed.
Old May 18, 2019 | 02:10 PM
SoInG's Avatar
Thanks for your help. I will check it out.
Ichiglo_
Mar 22, 2019 11:04 AM
ZGagnon
Engine - Intake/Fuel
Jan 26, 2013 06:00 PM
5150DS
120
Aug 15, 2012 10:48 PM
msburton
Intake & Exhaust
Nov 12, 2008 02:00 PM
