Electrical systems going haywire BCM?
Old Jun 30, 2019 | 09:21 PM
MMerk's Avatar
6MT
Unhappy Electrical systems going haywire BCM?
I was driving my 03' 6MT today (270,000 miles (80F warm day)) and all of a sudden my HVAC system shut down. HVAC digital dispay still on but I cannot adjust anything and the fan motor isn't working. SAT-NAV not working. Locks going intermittently. Then the engine would cut out a bit here and there and finally didn't want to go over 1,000rpm. I shut it down and waited about 10 minutes and it allowed the engine to rev again and i high tailed it home about 2 miles and then started acting up again. The car will still start however "Service Engine Soon" "Slip" lights are on. When the car is off and ignition is on the dash lights pulse and the HVAC system still is lit but inoperative.
BCM dead ringer?
Thanks,
Max
Old Jun 30, 2019 | 10:47 PM
Scorpi0's Avatar
Step #1: Pull the OBD code.
Old Jul 1, 2019 | 11:40 AM
MMerk's Avatar
6MT
Code is P0451 from the bcm
Code P2135 from bcm
Old Jul 1, 2019 | 03:33 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
P0451 is an EVAP problem which can cause engine malfunctions.
Old Jul 1, 2019 | 03:35 PM
cleric670's Avatar
BANNED!!!
P2135 is the throttle position sensor which will definitely cause problems.
However it's odd they would both fail at the same time. I suspect you have a battery cable loose or dirty so clean that up, reset the code, see what comes back.
douglas555
Feb 8, 2019 07:48 AM
Townshend
Apr 7, 2012 12:57 AM
theshawn
Jun 7, 2008 11:31 AM
entranzdG
Jul 8, 2007 11:17 AM
