Oil Consumption Normal?
Old Jul 19, 2019 | 03:11 PM
Tsz Mak's Avatar
G35X AWD
I've been oil changing my 06 G35x every 5k miles. Just recently noticed when I drain it only leaves me with about 3QT. So it's roughly missing 2QT every 5k. Is this normal for a 120k car, or should I check it out to prevent any other issues?
Old Jul 19, 2019 | 05:14 PM
Fletchaa24's Avatar
G35x awd sedan
Our cars love to eat oil that's why I like to change mine every 3k miles
Old Jul 19, 2019 | 05:32 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
And you should be checking and topping off your oil weekly.
Old Jul 19, 2019 | 06:02 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
My 04' has ate that much or more since it had 125k on it. My 05' with 160k does too. I check and fill them every 1-2 weeks. The oil rings wear down, get caked up and they start to eat oil, a hone and rering would fix it but most people don't want to go through that much work to fix it.
Old Jul 19, 2019 | 11:39 PM
gary c's Avatar
You need to check your oil level frequently! You have no idea when the first quart went missing or what running that low did to your engine, and then there's the second quart! Best way is to check your dip stick in the morning before you leave home, all the oil is in your pan so you get a true reading!
Gary
Old Jul 22, 2019 | 09:41 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Pretty typical with the VQ35, my first Maxima went through a quart every 1500-1800 miles. My G35, a quart every 5000 or so miles. Its not my daily driver so I only have to check the oil about once a month.
GrayG35
Nov 15, 2016 12:54 AM
bocatrip
May 20, 2015 03:25 PM
shimelho
Nov 12, 2014 04:02 PM
daniel-6speed
Mar 16, 2008 07:04 PM
CalRSX07
14
Feb 27, 2008 11:33 AM
