headlight upgrade
headlight upgrade
i am a proud new owner of a 4 door g35, unfortunatly it came with normal lights and not the HID. I was wondering if anyone knew of a somewaht inexensive way to get the HID kit. Or if someone knows of just lightbulbs that are real true HID looking.
I put the Sylvania Silverstars in mine. Changed out highs and low beams. Very white and much, much brighter than stock. Very white, not blue at all. Not sure if that is what you're looking for. BIG improvement over the stock bulbs.
Mark
Mark
NO halogen bulb can replicate HID. True performing HID in a halogen with the same stock rating, not possible. True looking, well opinions vary. You can purchase "blue" bulbs and make your car look tacky and dim.
For the long haul, it is a better idea to get the full OEM G35 HID headlamps assemblies and swap them out. Your true HID will last longer, look better and have the lighting performance that we all need at night.
Going this route is an especially good idea if you hate replacing bulbs back there every few months (depending on drive).
Silverstars are whiter because of the coating on the bulb. However, they are not brighter than your typical standard halogen bulb. Objects do reflect better because of the Kelvin color, but again it's not brighter.
Aftermarket kits MAY be avallable for this car, depending on the type of bulb used. 9006? 9005? etc. If its a standard type, you may get lucky. Price, however, is another thing. Most aftermarket kits I have seen run 800 to 1200 dollars. Remember, it's not just a bulb replacement, you must also add the ballast units for each bulb. These are high voltage power supplies. Not cheap.
Hey, I have the stock HID's. Now for the the high beam and the fog lights, wut should I do? Do I need to get a new setup or just new bumbs? I've seen some on the street that lookin real good, not yellow fog lights and even the trun signal bulbs are clear/white.. Thanks in adavance
Jason
Jason
Jason
Jason
Put silver starS in the fogs.
HID bulbs
Originally Posted by SweetNlow
Hidexpress.com can fix all you need for the headlights. They have the HID kit. Also pretty aftermarket bulbs.
Our low beams (non-HID) are H1 bulbs. You can buy just a ballast-and-bulb kit and put it in your existing light assembly w/ very little modification. There should be no problems w/ anything as most of these are plug-n-play. You can get an x-tec kit from M3motorwerks.com for $345 (the car manufacturer doesn't matter, only bulb type). Most common color temp is 5000-6000K.
