changing from yellow halogens to blue?
anyone change there regular halogens to HID/xenon on a 03 model? i’m reading that a conversion kit is needed, other times i see youtube tuts and the owners just plug them right in. anyone done this before? don’t want to buy something that doesn’t work or just out right starts to smoke.
thanks for the insight boss, wondering if they make blue halogens at this point. not trying to buy a kit just to get blue lights
OP the loss of usable light isn't worth the switch to a "cool" color, your lights are a vital part of the safety systems on your G. You'll be better off with a 5000K-6000K bulb. They still produce acceptable lighting output and the 6K will have a very slight blue tint. Remember the farther away from 4300K you get the worse the effective light output gets. Pardon my French here but people that run 8-10K bulbs are idiots.
every time i search for what size bulbs my car takes it is showing me HID Xenons. but don’t i need a damn conversion kit for that!!!! what halogens do i need this is frustrating
Halogens are very limited in color output and most still look too yellow.
And yes...if your car is a coupe, it should already have HID headlights. U will only need to replace the bulbs. The difference is in the headlight housing style between the years.
03-05 = Reflector headlights. (Requires D2R type bulb)
06-07 = Projector headlights (Requires D2S type bulb)
i feel like i’m missing something here. when i type d2r it only shows me xenon and led lights lol i have a 2003 model shouldn’t it be halogens. i’m usually really good with this but what gives smh
No, all the 03-07 coupes use xenon bulbs for their low beams. The difference is in how the light is projected: 03-05 uses a reflector type housing. 06-07 uses a projector type housing.
so is i believe what i want to know is what bulb is a D2R? is that a halogen bulb? that will narrow down what i need to buy. i know i need a d2r but when i search that it shows me xenons
D2R is an HID bulb. And don't buy cheap ones unless you like replacing them. Go with Phillips, quality stuff.
If you haven't replaced the bulbs before, watch a couple YouTube videos first, you have to go in through the fenderwells.
If your coupe is an 03-05 with OEM headlights, get the D2R.
If your coupe is an 06-07 with OEM headlights, get the D2S.
That should clear it all up lol.
i have the 03 sedan is that the same guidelines you gave me ??
gpeters
Jul 21, 2004 11:06 PM
