Wiper motor - interchangeable???
Old Aug 23, 2019 | 03:33 PM
art.is.zan's Avatar
G35 RWD
Greets all - the original wiper motor in my 2003 g35 sedan died approx 18mos. ago - took it to the mechanic for repair at close to a $400. fix with a remanufactured part.
Couple days ago, i'm on the road - it starts raining - go to turn on my wipers and *nothing* !!
I'm thinking this time around to go with a used OEM part - wondering if the wiper motor from a 2005 g35 sedan would work in my 2003?
Any info or other insights greatly appreciated!
- zan
Old Aug 23, 2019 | 03:57 PM
telcoman's Avatar
Veteran: Army
- zan
Have you done any troubleshooting using your multimeter prior to assuming the problem is the wiper moter?
Are you getting voltage at terminal 18 at the IPDM?/wiper moter
Are you getting ground thru the combination switch?
https://nicoclub.com/FSM/G35/Sedan/2003/ww.pdf
See page WW-16
Telcoman
Old Aug 27, 2019 | 11:01 AM
art.is.zan's Avatar
G35 RWD
Appreciate the insight Telcoman - I'm not a mechanic, will have my mechanic friend check everything you've mentioned.
Though the question still stands - if it is a faulty wiper motor - would the 2005 part be interchangeable on a 2003?
Thanks...
- zan
Old Aug 27, 2019 | 12:38 PM
telcoman's Avatar
Veteran: Army
......- if it is a faulty wiper motor - would the 2005 part be interchangeable on a 2003?
Thanks...
- zan
Perhaps that question could best be answered by an Infiniti Parts Department?
Old Aug 28, 2019 | 06:10 PM
05_SkylineSedan's Avatar
20 Year Member
It's not the same part number. Seems to have changed after '04:
2003/04: https://www.infinitipartsonline.com/...tor-28815am600
2005/06: https://www.infinitipartsonline.com/...tor-28815ac700
Old Sep 3, 2019 | 12:23 PM
art.is.zan's Avatar
G35 RWD
Thank you so much 05_SkylineSedan !!!
Just got off the phone with infinitipartsonline.com - they verified the exact part necessary - brand new Infiniti OEM - placed order... one happy girl
- zan
Old Sep 3, 2019 | 12:35 PM
art.is.zan's Avatar
G35 RWD
---> thank you as well Telcoman - my mechanic friend did check all your suggestions - was the wiper motor itself - appreciate all the help!
- zan
Old Sep 3, 2019 | 01:55 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
- zan
Which part number did they tell you was correct?
Glycerine
Apr 22, 2016 04:29 AM
xxcabxx50
Engine - Complete Motors
Jul 3, 2014 07:57 AM
jclit
Jun 20, 2006 03:52 PM
87 IROC-Z 350
Feb 19, 2006 03:53 PM
