How Variable Valve Timing Works
Old Oct 1, 2019 | 08:06 PM
speedkar9's Avatar
Infiniti G35
Here's how the variable valve timing system works on your car:
Varying valve timing yields improvements in emissions, increases fuel economy and gains in power.
Here you can see the valve train - with the VVT actuator being the larger gear connected to the intake camshaft:
Here's a look underneath the engine head at the valves:
The VVT actuator is the heart of the system, using oil pressure built up inside chambers to rotate the output shaft relative to the input shaft, changing the phase angle:
See the small holes where oil travels into the chambers:
This is the solenoid the controls oil flow through the camshaft to actuate the timing gear in advance or retard:
Old Oct 2, 2019 | 12:59 PM
Urbanengineer's Avatar
Love this stuff. Keep it up .
Jabaree12
Mar 14, 2013 05:20 AM
nsyr
May 6, 2009 08:16 PM
NETSHARK
Jan 17, 2007 11:45 PM
