Wiper hose broken
Old Jan 27, 2020 | 05:18 PM
DrPleaser's Avatar
G35X
Wiper hose broken
Hello all, I'm a fairly new G35X buyer and I've recently had a wiper issue where the passenger side wiper had no liquid coming out.
I did some troubleshooting and found this:
how bad is it?
Old Jan 28, 2020 | 02:16 AM
herrschaft's Avatar
Should be an even fix. You can buy a rubber hose at hardware stores. Is it just the hose or is that plastic part on the cowling broke?
Old Jan 28, 2020 | 02:18 AM
DrPleaser's Avatar
G35X
Plastic part snapped off sadly
Old Jan 28, 2020 | 11:30 AM
Scorpi0's Avatar
Looks like Part # 27461JA
https://www.infinitipartsdeal.com/pa...ld_washer.html
Old Jan 28, 2020 | 11:38 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
For the future be sure to ONLY use winter-rated washer fluid when it's below freezing, typically things like that happen because people use water for wiper fluid and it freezes and breaks pieces like that.
Empty the system by running the washer fluid until it's empty, then refill with winter fluid, then pump more out to make sure the line was completely purged of the old stuff.
Old Jan 28, 2020 | 12:07 PM
DrPleaser's Avatar
G35X
Hahaha, I would be insane if I did that up here in Quebec. I always have -40 washer fluid. I'm guessing that I was cleaning ice off of it too vigorously and it sheared off .
Old Jan 28, 2020 | 12:26 PM
cleric670's Avatar
BANNED!!!
Yeah I suppose that could happen too.
If you cleaned it thoroughly with isopropyl alcohol you MIGHT be able to super glue it back on if you used very little glue so it didn't get into the hole in the middle.
Old Jan 29, 2020 | 03:38 AM
DrPleaser's Avatar
G35X
Here's another picture:
Also, how do I get that part off the tube ??? just plain old elbow grease?
Is it easy to put back on?
Old Jan 29, 2020 | 04:46 AM
Scorpi0's Avatar
Yeah. Twist and pull.
Old Jan 29, 2020 | 09:34 AM
depmike38's Avatar
5 Year Member
g35X 4dr sedan
Everywhere it slips on nick it with a straight edge razor blade so it can twist loose easier. everything those hoses attach to is plastic and probably getting brittle. Then just push the new hose one until it gets a little ways past the barb.
Old Jan 30, 2020 | 01:44 AM
DrPleaser's Avatar
G35X
So to be sure,
Originally Posted by Scorpi0
is the correct part to get?
Old Jan 30, 2020 | 02:13 AM
DrPleaser's Avatar
G35X
I think I got it
28937-AQ000
Old Feb 5, 2020 | 02:32 AM
DrPleaser's Avatar
G35X
It's done! A small plastic part + elbow grease = fully clean windshield now! thanks to everyone for responding.
28937-AQ000 was the part I needed. Pretty cheap from the dealer!
Old Feb 5, 2020 | 02:54 AM
Scorpi0's Avatar
Nice! Which parts diagram did u find that part in? Its not in the one I posted.
Old Feb 5, 2020 | 03:06 AM
DrPleaser's Avatar
G35X
Which is weird as my vin says 2006 g35x sedan
