Looking for transmission cooler kit or what to buy
Old Apr 17, 2020 | 03:21 PM
3000vr4tt's Avatar
05 g35x. Im trying to see if there is a bolt on kit or i would have to buy a universal one, also if i would need a fan. Mods are lmt intake, nwp tbody, motordyne 5/16 spacer, uprev tune, dc headers, berk test pipes, megan ypipe and catback, 1step colder plugs, gordgee ground wires, spitfire coil packs
Old Apr 19, 2020 | 03:46 PM
3000vr4tt's Avatar
Bumpp.. dont want to shell out money for a stillen if theres a better priced option thanks guys.
Old Apr 20, 2020 | 12:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If you want a 100% bolt-on cooler that's pretty much your only option. Otherwise start measuring to see how much room you have to work with and order a generic cooler in the size you need from Summit or Jegs. You can get away with regular rubber transmission line hose and worm drive screw clamps but you should look into getting some AN fittings for it instead (usually have to tig on the fitting to the cooler), blowing a tranny line sucks.
Personally I would probably just go for a generic with AN fittings which will add a little to the price tag but still probably be cheaper than the Stillen. If you don't have access to a tig welder then you either need to get a cooler that already has AN fittings or pay someone locally to weld them to the cooler.
You don't need a fan for a tranny cooler unless it's being installed in a fender or somewhere with no airflow.
You should also inspect your plugs, you shouldn't need colder plugs with just FBO, they probably won't be hot enough to keep from fouling.
Old Apr 21, 2020 | 10:59 AM
3000vr4tt's Avatar
Thanks bro
gat0713
May 25, 2011 08:32 PM
cmesidewayz
Mar 30, 2011 05:33 PM
mjcn121789
Jun 26, 2010 07:49 PM
REDG35DRIVER
14
Nov 30, 2009 04:02 PM
coup de grace
Tuner & Dyno
20
Dec 19, 2008 08:39 PM
