Bell Raceworks Differential Brace
Old May 13, 2020 | 07:20 PM
srv2nv's Avatar
G35 Sport
Bell Raceworks Differential Brace for the 350Z/G35
https://bellraceworks.bigcartel.com/...-factory-cover
Anyone ever install one of these on the G35 sedan?
I ended up picking one up for a decent price, but the problem I'm having is the trunk hangs down in front of the sub frame on the sedan, preventing me from being able to slide the bolt and metal tube into the existing hole.
I've thought about dropping the back 2 sub frame supports but wasn't sure if the sub frame would be able to support the weight of the differential without breaking or if the front sub frame bushings would allow the rear to drop enough for me to slide the bolt in.
I was hoping someone might have some experience and would be willing to share some knowledge.
Old Aug 11, 2020 | 07:08 PM
srv2nv's Avatar
G35 Sport
After talking to someone on IG who gave me some great info, I ended up jacking the car up from the side to give myself more room to work and jamming my hand up in between the sub frame and differential to insert the bolt from the other side.
There isn't much room to work but the bolt will go in, and then you simply slide the sleeve over the bolt from the other side and install the brace. Easy job, looks good, and hopefully will keep the diff bushing from blowing out on me.
Swaglife81
Dec 16, 2016 09:51 AM
845infiniti
Feb 2, 2015 12:30 PM
g's uppp
Mar 4, 2007 11:54 PM
bconrey
Jun 15, 2006 11:10 AM
NathanOfSeattle
Mar 30, 2003 02:54 AM
