Rev problem
Old Jun 23, 2020 | 07:41 PM
Jonathan Sims's Avatar
Base Sedan
Originally Posted by Scorpi0
Just tried. Mine wont go over 2300 RPM.
yea someone gave me some info that it’s because of the brakes that it has a safety feature in it to not let you go over that but if you put a toggle switch in between them tot where the brake lights don’t come on the it will work or you can unplug the abs under the hood but you won’t have traction control or anything. I wonder if that’s the same if you take out the abs fuse too so that way it will cut off a different way
Old Jun 23, 2020 | 08:07 PM
Scorpi0's Avatar
I actually have a switch in my car that will fully turn off VDC. I can try with it off and see if that makes a difference.
LrgMendoza
Nov 2, 2011 11:01 PM
dls160
Sep 15, 2005 10:41 PM
