Any help would be appreciated
Old Aug 27, 2020 | 05:35 PM
Kevin Ebbett's Avatar
Stock g35 sedan with throttle body spaced also have test pipes with a manzo cat back
Just did a swap in my 04 g35 sedan took a engine out of a 05 g35x changed upper oil pan to make it work now Ita giving timing codes and I have zero throttle respons any idea how I can fix this the codes I got are p0011 p0021 p0506 v1001 p1612
Old Aug 28, 2020 | 05:55 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take the cam and crank sensors out of the old engine and put them in the new engine. P0011/0021 can be caused by a bad sensor and the previous engine had known working sensors yes?
You also need to perform other sensor recalibrations for the new engine, specifically the THROTTLE CLOSED POSITION and IDLE AIR RECALIBRATION. Steps are all in the FSM in section EC - Engine Controls at the front of the book under "basic service procedures".
U1001 is a CANBUS error, sounds like something is still unplugged. Did you disconnect anything else besides just engine components? It's basically saying that somewhere in the local network of various computers on the car that SOMETHING is disconnected and the ECM can't talk to it.
P1612 is a NATS/IVIS (security) code meaning something is wrong with the system, that's PROBABLY what is disconnected. There's a lot of various components interconnected those systems but AFAIK none of them are located in the engine bay.
Dannyg35c¿
Sep 7, 2020 11:33 PM
ShoTheG35xOwner
Mar 29, 2020 12:09 AM
G35NBOOB
Jul 22, 2016 02:48 PM
yeeunit
Jun 6, 2015 10:23 PM
Zephyr
Mar 28, 2014 10:00 AM
