P0138
Old Sep 3, 2020 | 12:07 PM
teemason's Avatar
G35 Sedan
P0138
I still have the P0138 code after tuneup. Has anyone ever changed the Bank 1 Sensor 2? Do you know the part number?
Old Sep 3, 2020 | 11:19 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Nissan part number 226A0-AM601
However I would just use a reputable aftermarket like a Denso, Bosch, Hitachi, etc.
As for the replacement, I STRONGLY recommend you get under the car and soak the welded bung in PB Blaster for 3-5 consecutive days to try to draw some of the penetrant up into the threads, they can be extremely difficult to remove on some vehicles. Don't try to do it with the exhaust hot this is something you want to do on a 100% cold engine that hasn't been started that day.
Worst case scenario you will be cutting the entire bung off and welding on a new one (quicker and easier if you have a welder, if not any muffler shop should be able to do this for you) Be sure to use high-temp anti-seize on the threads of the new one. thread size should be M18x1.5 for the new bung but double check on the new sensor.
Old Sep 7, 2020 | 10:28 PM
srv2nv's Avatar
G35 Sport
Make sure you don't have any leaks in the gasket after the cat first. I had this code before and it was due to the cat/y pipe bolts rusting apart.
lgbent
Aug 14, 2020 06:57 PM
Serna
Jan 6, 2020 06:07 PM
Kenneth Tran
Apr 28, 2016 05:57 PM
draco1020x
Jan 20, 2011 04:11 PM
officerdbag
Feb 14, 2010 10:54 PM
