codes
Old Dec 14, 2020 | 12:49 PM
Horacio Perez's Avatar
Awd
codes
I just got a p1168 code and a p1051 code for my 2004 Infiniti G35 have the service engine soon light on how worried should I be
Old Dec 14, 2020 | 03:54 PM
telcoman's Avatar
Veteran: Army
As Alfred E Newman always said. "What me worry"
Check out the FSM EC section
https://www.nicoclub.com/service-man...F2004%2Fec.pdf
See Page EC 462
Good luck
Old Dec 18, 2020 | 02:08 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
P1168 can't completely closed loop on bank 2, look for vacuum leaks, pull and inspect spark plugs, real-time scan the O2 sensor to make sure it's working properly.
P1051 is a generic code because your scanner doesn't have protocol 9141-2 needed to properly read codes for this car. Use a different scanner with the correct Nissan protocol.
Old Dec 18, 2020 | 11:44 PM
Awd
Thank you
will do
Old Dec 19, 2020 | 06:11 PM
seymore4's Avatar
m56
P1051 is Air/Fuel Ratio Sensor Heater Bank 1.
Old Dec 20, 2020 | 12:45 AM
cleric670's Avatar
BANNED!!!
That's actually a generic for sensor 1 bank 2 heater.
With the proper protocol scanner it will probably come back as P0051 for low voltage signal or P0052 for high voltage signal.
However sometimes it comes back as something wildly different. Gotta use an OBD2 scanner with the correct protocol.
It's basically comparing variations of the english language, there's brooklyn english, southern english, british english, australian english, etc.
Scanner doesn't know if it's a "dickey", a "boot", or a "trunk". All three words are used to describe the rear storage compartment of an automobile depending on which variation of english you speak.
teemason
Oct 30, 2020 10:14 AM
G35 Owner
Dec 18, 2010 12:15 AM
Xet
Northern California
20
Jul 31, 2008 07:10 PM
Foo_G
Oct 22, 2006 08:39 AM
basus
Nov 14, 2005 01:58 PM
