2006 V6 G35 strong fuel smell in plenum
I own a 3.5L V6 G35 and have noticed a very strong gasoline smell when I take off the upper plenum. It is as if you put your nose in the gas tank fill hole. I know this is not normal and could be dangerous. The engine has very high NVH and when I used an OBD tool, random misfires were detected on 2 or more cylinders (error code P0300). This occurred immediately after I changed the valve head gaskets, which were leaking previously. Which hose/gasket would be the most likely culprit? What would be the first thing I should check?
Strong fuel smell in the intake is probably a leaking injector. Tear it down to the lower intake collector, prime the fuel pump (key in ON position) then use a flashlight and paper towel to see if fuel is drizzling out of an injector.
FreshTortilla
Mar 11, 2020 08:46 PM
AznIceRckt
Intake & Exhaust
Feb 21, 2004 08:27 AM
