Repair? Sell? Keep?
Old Sep 27, 2021 | 02:21 PM
TeddYang's Avatar
Ohio G Club Member
Unhappy Repair? Sell? Keep?
2005 DG 6MT G35 Sedan with ~140k miles and no oil burning issue
So after 15 years and 140k miles of running strong it finally happened. Car sputtered and engine died while on the 110S between LA and Pasadena (which if you've been on that stretch of freeway, it is not a great place to breakdown). Fortunately it was the middle of the night and traffic was light, CHP was able to push the car to a safe spot and i was able to get the car towed back home. Initial diagnosis is a bad alternator so which i was quoted $1k to repair. The question now is, do i get it repaired? sell as is? repair then sell? or repair and keep? Some additional context, the car is no longer my DD but i kept it around as a fun car to drive. What would you guys do?
Old Sep 27, 2021 | 06:35 PM
MooseLucifer's Avatar
5 Year Member
blk
Repair and keep! Love my 6MT sedan, don't see ever getting rid of it - and it has 195k and a salvaged title!
Old Sep 27, 2021 | 09:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'd keep it but get another quote, $1k for an alternator is pretty steep, I would expect Infiniti to charge that much.
If that WAS a dealership price then ok.
Old Sep 30, 2021 | 09:13 PM
broke_as_ajoke's Avatar
I'm sure you can get an alternator cheaper than 1000 bucks.. I would call around..
here is one cheaper
another one at Z1
Old Oct 1, 2021 | 01:14 PM
cleric670's Avatar
BANNED!!!
It should only be MAX a 3 hour labor charge for the alternator, it's tucked into a sort of crappy location so I could see 3 hours being billed to the customer even though it only takes me about 90 minutes total.
-Disconnect battery
-Drain out about 1/2 gallon of coolant
-Remove upper radiator hose
-Remove radiator fans
-Car on jackstands or lift
-Take off the primary belt
-Unbolt the alternator wire and the plug-in harness, angle head needle nose pliers are your friend.
-Remove the two little alternator bolts, you will need a small gear wrench or this part will take forever, it's like 7, 8, 9 mm, something small, can't remember.
-Remove the two large bolts.
-DONE
Getting your alternator rebuilt locally is also an option, cost me $200, then you keep the OEM unit but rebuilt to new spec.
Old Oct 2, 2021 | 10:22 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Couldn't see selling an otherwise reliable car over an alternator.
mostestG35
13
Aug 15, 2015 05:56 PM
seekinganswers
Mar 24, 2013 11:58 PM
MoxaBall
Northern California
11
Oct 4, 2008 02:32 PM
o1owest
May 26, 2005 09:48 PM
crapweasel
Apr 14, 2005 09:36 AM
