2006 G35 Sedan
Old Nov 16, 2021 | 09:02 PM
romansan2008's Avatar
2006 G35 Sedan
I have an Evap System Question
On the sedan rear right ( other side of muffler) there's the evap canister on the outside there's a plastic cover to cover the canister while removing that cover 4 bolts to replace the Vent Valve all bolts broke.
Does anyone know the part numbers for the mounting brackets so I can replace them and put that cover back on to shield the Evap Canister.
While im at it I may just replace the canister too.
If not, Ill try to drill them out and just put 4 screws.
I haven't removed the canister yet because im scared ill brake more bolts. don't want to attempt without new brackets or other options.
Thank you all in advance.
Old Nov 18, 2021 | 12:08 AM
MooseLucifer's Avatar
5 Year Member
blk
Hunt around here, great resource for part numbers.
https://infiniti.7zap.com/en/us/g35+...35/12+411+608/
Old Nov 18, 2021 | 07:05 AM
thank you.
I see section 223 where the canister is but I can’t seem to find all the brackets that the canister bolts on to and the brackets that the cover/trim panel bolts to that protects the canister. Canister area has a bit of rust, just brackets, body is good and I’m happy about that.
I’m rebuilding my g35 so I kind of want to replace all the rusted brackets under the car.
I already replaced/upgraded all the brackets under the car except the canister area.
new engine/trans, exhaust, upgraded fuel system. All damaged shields etc.
she almost a new car now
ill keep looking.
Old Nov 20, 2021 | 11:26 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You might have to cable tie that cover back on. Thomas & Betts makes some excellent heavy duty UV resistant ty raps that are 18" long that I would be perfectly comfortable using for something like that.
Old Nov 20, 2021 | 11:53 AM
that will be my last option.
im still going to find usable brackets somewhere.
I may be able to clean up mine I hope if I can’t find new ones
856_reilly
Oct 7, 2011 12:46 AM
jibberjabbers
Accessories
May 29, 2011 04:09 AM
cliffords
Aug 7, 2009 02:00 PM
dallasg
Dec 14, 2005 08:40 AM
