Brake Bleeder Screw Leaking Around The Threads
I flushed the brake fluid and now one of the brake bleeder screw is leaking around the threads. It's not loose and it's not leaking from the top. Any idea how to fix it?
Bleeder valve should be the same torque, caliper to knuckle bolts are closer to 85 ft-lb, but I don't know off the top of my head.
Bottom angled edge of bleeder should seal against the caliper below the threads, so when you remove it check for damage or FOD on the bleeder or caliper.
Actually for some odd reason it shows the front and rear bleed screws as different torque spec, 69 INCH/lbs is plenty though. Usually when I tighten it by hand with a wrench it ends up being just slightly undertorqued and that's more than enough to seal.
y.dan
Jun 22, 2006 07:50 PM
