Brake resivour leaking what would cause this to happen
Old Feb 19, 2023 | 07:38 PM
Oletufano859's Avatar
It's basic
I noticed today that my brake resivour was leaking where it connects to the master cylinder not very familiar with it what would cause this?
Old Feb 20, 2023 | 02:35 AM
Scorpi0's Avatar
U sure its leaking or its just residual fluid?
I would inspect the whole thing and find where its leaking from. Might be a cracked reservoir.
Old Feb 25, 2023 | 11:50 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Spray it down clean with brake parts cleaner, rinse gently (watch out for the electrical components like the ABS relay and such) or wipe it all off with a rag and see if it comes back.
Also fill the brake reservoir and see if it drops over a month. It's not accurate to check it right now because that fluid level does decrease as the brake pads wear and the brake caliper pistons are further extended as those pads wear.
EDIT: If that fluid does start to pool around the rear of the MC again then it's probably a failing seal in the brake master cylinder.
G35CO
Nov 28, 2021 01:06 PM
stockae92
Nov 17, 2014 08:46 PM
RedBaronK
Mar 13, 2011 11:03 PM
jnkirk1974
Sep 18, 2005 04:02 AM
