06 G35x sedan 194k miles, car has a high idle it would idle at 1500-2000rpm, oil smells of gas and just gets thinner. Sparks plugs smell of gas, exhaust is letting white smoke out with the smell of gas. Have done a compression test and changed spark plugs.
cleric670
BANNED!!!
close
- Join DateMay 2017
- LocationWashington State
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideCoupe 6MT Premium RAS
Liked:2,497 Times in 2,182 Posts
I'd do a leakdown just to make sure you aren't dealing with a blown up engine.
What codes is it throwing?
cleric670
BANNED!!!
close
- Join DateMay 2017
Random misfire code, I'd start with fresh plugs, check for vacuum leaks, thoroughly inspect the coils, see if the code goes away.
