2006 G35X Powers On But No Crank - Shifter Interlock Problem
(Micro switch has been removed. When the shifter is depressed, the shaft makes contact with the micro switch. The micro switch releases the shift lever from Park.)
Greetings Everyone. I have a 2006 G35X. It powers on but no crank. The problem arose when I bypassed a micro switch for the shift interlock release located on the underside of the shifter assembly. I bypassed it because the micro switch was damaged.
I should have just replaced the shifter assembly, but I cheaped out and now I am paying for it.
I checked all of the fuses and they are good. There is no codes either.
Does anyone have any ideas? Please let me know. Thank you all!
(Update! The issue has been found
G35x7777
Sep 15, 2019 01:43 AM
