Swapped 03/04 reverse lights onto my 05, now reverse lights don’t work
Old Oct 21, 2023 | 08:43 PM
nik05g35x's Avatar
G35X 5AT
Exactly as title states, I picked up the trunk part of some 03/04 tails, swapped them into my 05 and now the reverse lights don’t come on, and they don’t light up at all. The problem started when I swapped the right side in, the original one on the left side stopped working, I thought maybe swapping both would fix it but still neither turn on. Will try switching back tomorrow to see if it fixes it. Any idea why the 03/04s don’t work?
Old Oct 22, 2023 | 09:28 AM
05_SkylineSedan's Avatar
20 Year Member
You mean you swapped the bulbs only, right? Should be the same 18w bulb. Maybe you accidentally popped the fuse - which is #83 in the IPDM?
hL.
Jan 25, 2011 02:38 AM
Scuba235
Lighting
Feb 19, 2008 05:39 AM
infocalypse
Apr 21, 2005 08:21 AM
ryansg35
Apr 11, 2005 07:28 AM
