Suspension problem. Advice appreciated
Old Mar 14, 2024 | 02:54 PM
timothymiles's Avatar
2004 G35X 4dr Sedan 217K miles
I was lubeing my power steerting u-joint the other day and discovered another, possibly more serious problem. There is a part of my suspension that has failed or broken. I'm having trouble finding that exact part so I can order it and also don't know if this is a "get it fixed sometime" or a "get it fixed as soon as convenient" or a "Don't drive it anymore until you fix it.. you could die!!!" issue. Obviously, it doesn't seem to be having a negative effect on driving to this point.
Also, can you tell me if this can be fixed by replacing one or do I need to buy both parts? A picture of the situation is attached.
Thanks
Old Mar 14, 2024 | 04:01 PM
Urbanengineer's Avatar
Probably will just need the arm, but if it’s rusted tight you probably are going to want to have the lower control arm.*
Old Mar 14, 2024 | 05:01 PM
Probably will just need the arm, but if it’s rusted tight you probably are going to want to have the lca
Sorry.. but it appears as if your entire thought was not displayed here. I really appreciate the input and would appreciate the rest if possible.
thanks
Old Mar 14, 2024 | 09:00 PM
G2B35AGN's Avatar
He shortened "Lower Control Arm" ... lca
Old Mar 17, 2024 | 07:08 PM
Got it.. if it had been in caps I probably woulda figured it out but I can be pretty dense at times. I'll blame it on my age.... And thanks to both of you.
Old Mar 19, 2024 | 09:08 PM
thanks
my bad! Bad punctuation and lazy spelling. I blame this phone.
socialconflicts
Jan 17, 2011 03:42 PM
MAUI808
Jan 12, 2009 07:31 AM
littlerudegirl
Apr 29, 2007 10:00 AM
KAHBOOM
Aug 1, 2005 01:15 PM
