2003 ignition issue
Old Mar 14, 2024 | 05:56 PM
teemason's Avatar
G35 Sedan
2003 ignition issue
I noticed that when I start my 03 sedan that the key does not snap back so I have to manually move it to the correct setting for the radio and A/C to work. I think it is a bad ignition switch. Any idea on what the problem could be?
Thanks
Old Mar 16, 2024 | 03:02 AM
Scorpi0's Avatar
Sounds like a bad ignition switch. Try spraying some lube into the cylinder to see if it helps. (Your keys will get oily the next few times u insert it and take it out though).
Or remove the switch and disassemble it. Theres probably a spring in there that needs some fiddling with.
rh04g35
Jul 16, 2018 02:57 PM
danpjenz
Jul 2, 2015 10:27 AM
jeffg35az
Oct 23, 2014 06:05 PM
LV310G35
Feb 6, 2010 10:47 AM
