Temp guage only goes up to 1/3 never to half way
Old Oct 4, 2024 | 09:01 AM
DiyDoIDoThisg35's Avatar
Infiniti g35x sedan
My g35 temp guage never goes up to 1/2. I recently replaced the thermostat thinking that was the issue but the issue still persist. I also checked my coolant temp with a scan tool and my temp is at 88 to 89°c which is right in the good range for these engines. Both upper and lower rad hoses are warn also. Any ideas?
Old Oct 4, 2024 | 11:17 AM
05_SkylineSedan's Avatar
20 Year Member
I'm pretty sure your temp gauge is working properly. You've confirmed the actual coolant temp is good so I don't think there's a problem. I seem to remember our '05 and '06 Gs normally displaying temp at about 1/3. It gives you more of a chance to notice if temps start climbing. There is a "test mode" which will run your gauges through their full sweep - but I can't remember how to do it. Maybe somebody else here can describe that for you.
Old Oct 5, 2024 | 12:39 AM
Scorpi0's Avatar
Yeah my normal operating temp always stays at a little under halfway.
Old Oct 12, 2024 | 04:00 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
It sits below half on purpose but not specifically for that reason, it just seems to be an industry agreed upon standard. The temperature is actually fluctuating all the time and the gauge is dampened to prevent small deviations from being noticeable and panicking the average driver. It's probably less of a temperature climb from where it normally sits to the high end than you would think. And anything above half means you definitely have a problem!
nickt921
Aug 19, 2022 09:26 AM
Chris Davies
May 24, 2021 04:00 PM
KevSil616
Feb 12, 2020 01:04 PM
alKoh
Nov 15, 2016 03:13 PM
SE2002
Jul 10, 2008 10:59 AM
