Painting the brakes
Old May 15, 2003 | 05:00 PM
dohmer's Avatar
Painting the brakes
Anyone thought about or did spray painted their brakes to make them look like brembos? What color do you think would look good other than gold?
Old May 15, 2003 | 07:06 PM
IQ9's Avatar
IQ9
Re: Painting the brakes
If you do it use an engine enamel-it won't get burned off. The gold on the brembos is a weird shade but hey, you go'em I don't. I will paint mine later-the weather has been good enough.
03.5 Sedan/B. Silver/Prem/Winter/Aero/Tint/Rims
69 Chevelle Hard Top BB/4.11's/Posi
Old May 15, 2003 | 09:19 PM
pestilence's Avatar
Id like to paint them RED but I dont want it to look tacky or anything... ive seen people spray paint them and the spray paint gets everywhere.. if I do it.. i wanan do it the correct way :>
Old May 15, 2003 | 09:49 PM
ryoken's Avatar
I've seen kits for painting brakes. Don't remember where.
Old May 15, 2003 | 11:53 PM
IQ9's Avatar
IQ9
SCC mag,EuroTuner to name a few.
Old May 15, 2003 | 11:56 PM
IQ9's Avatar
IQ9
Use a plastic shopping bag to cover the disc and related suspension. It makes it really easy. Then tape off what is left exposed and start spraying. You want to use a lot of light coats. The frist one may not even really show much coverage but you will get great results that way. Slow and steady...hum...that sounds bad;P Try it it works if not and we meet at the Statewide meet I will show you in person.
Old May 16, 2003 | 03:04 PM
3point5SE_Auto's Avatar
laquer is what i have used in the past. i have a couple hundred thousand miles all told on laquer painted brake calipers. Do a search for "folia-tec", it is a canadian company, runs about 40.00 but will not chip or burn away. Note, take the calipers off when you paint it, cause no matter how careful you are you will paint something together that will bea pain to remove later such as shims, clips
http://foliatec.de/1_english.shtml search for "brake", then choose caliper laquer
Better Life thru Chemistry
Old May 17, 2003 | 07:47 PM
IQ9's Avatar
IQ9
Done 26 cars so far and NEVER removed the calipers. I am good with a can and tape & Bag.
Old May 19, 2003 | 11:42 AM
pestilence's Avatar
woohoo.. come over.
Old May 20, 2003 | 09:12 AM
IQ9's Avatar
IQ9
We'll have to set it up. It is easy but remember that you are not going to get ever inch of the caliper. You can, but that takes a long time and you have to keep yourself under the car alot longer than I perfer which leaves little room to hold the car at the proper distance. This leads to runs-no not The Runs
boostelevator
Brakes
Oct 5, 2015 08:56 AM
cmesidewayz
Sep 29, 2015 09:28 PM
Nog89
Sep 1, 2015 06:53 PM
