Lime removal
Old Mar 21, 2005 | 10:54 AM
mrmanishs's Avatar
Lime removal
Aargh.. go figure, 3 weeks after buying my beautiful white g35, which I love, i had some lime fall from the ceiling of my condo garage to the top of my car. Any idea how to get rid of Lime and is it possible to do without harming the paint?
manish
Old Mar 21, 2005 | 01:58 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
If you haven't washed it off yet, do it NOW.
The lime will etch the paint.
I had a similar experience lime dripped onto car all weekend
before i found it.
I ended up repainting.
Old Mar 21, 2005 | 02:06 PM
mrmanishs's Avatar
How do I wash off lime, is there a special chemical? Do I have to get it professionally do?Water is just not doing it, unless if i have to *scrounge* scrub it hard. A little got on the rear right window too.
Manish
Old Mar 21, 2005 | 07:19 PM
skeleton_cru's Avatar
Sedan
Have you tried any of the lime removal products? CLR? Lime Away? I don't know what this will do to your paint though.
Maybe try cleaning a very small spot first and see if it affects the paint?
Old Mar 21, 2005 | 09:54 PM
Noremac's Avatar
Recommend you don't start off with the strong products like CLR, LimeAway. Instead, try plain white vinegar. Use it liberally and let it soak on top. Apply light pressure, but only if the surface is otherwise clean and use plenty of liquid (vinegar). Repeat. If this still doesn't work, then try the other products. You may also consider using a mild wax/cleaner product.
Old Mar 21, 2005 | 09:58 PM
JimG35's Avatar
Lime ceiling? Or is it plaster, drywall? If water created the lime slime, water (can easily) wash it off. Any pigeons in your garage?
Old Mar 21, 2005 | 10:35 PM
ricmalaz's Avatar
I second the white vinegar (with caution of course). We have very hard water in the reservoirs around here and I used to get quite a bit of hard water spotting on my boat. I started mixing white vinegar in my soapy water when I washed the boat. Worked great! It took the hard water spots right off. But that was gelcoated fiberglass. So I don't know how it would behave on your paint.
Old Mar 22, 2005 | 07:34 PM
Noremac's Avatar
It's probably concrete leaching, aka efflorescence, which contains limestone. I've also had this problem happen to me in my work garage. I'll NEVER park in a certain spot again.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
