brake pads
Old Apr 21, 2005 | 09:20 AM
gdussau's Avatar
Question Brake Pads
I am trying to take off my pads on my sedan rear brake (no Brembo) but the screws seem to be stocked. I cannot unscrew any one of them.
Any suggestions to make it easier to unscrew them?
Thanks.
Old Apr 21, 2005 | 09:38 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
If you have an old socket, put it over the nut & give it a good rap with a hammer.
You could also try tightening too....
I know it sounds strange, but it works (work in both directions 'till free)
Else get a impact driver.
Old Apr 21, 2005 | 10:11 AM
gdussau's Avatar
I have already tried all the above.
Do you think there's a procuct (WD-40 or something else) that could help?
Thanks.
Old Apr 21, 2005 | 10:18 AM
ChicagoX's Avatar
Don't drink and Mag Race
I know this sounds kind of silly, but with the positioning of the caliper bolts, you might be turning them the wrong way......
WD-40 works.
You won't be able to remove the lower bolt due to the suspension, but back it off enough to rotate the caliper towards the front of the car, and you can get enough clearance to swap pads.
Old Apr 21, 2005 | 10:49 AM
gdussau's Avatar
To unscrew, am I right to turn from the back of the vehicule to the top (not toward the floor) of the vehicule and then toward the front of the vehicule ?
Old Apr 21, 2005 | 11:07 AM
SilverII's Avatar
Righty tighty ...lefty loosey!
Old Apr 21, 2005 | 11:24 AM
soad's Avatar
P B blaster works better than wd40
Old Apr 21, 2005 | 11:33 AM
ChicagoX's Avatar
If I understand you, yes.
The torque spec is 28-36 ft/lbs on the rear caliper bolts, so even if they are fresh, a small wrench that fits in the wheelwell will be difficult to turn, FWIW.
Don't forget to keep an eye on the brake fluid when you compress the calipers, or you will end up overflowing the reservoir.
W
Old Apr 21, 2005 | 11:34 AM
InTgr8r's Avatar
Except when you are behind the bolt/nut!!
Old Apr 21, 2005 | 11:39 AM
InTgr8r's Avatar
If I understand^^^
then you are tightening.
Old Apr 21, 2005 | 02:32 PM
Eticketride's Avatar
Lefty Lucy, Righty Tighty....
Clockwise is to tighten...unless it is a reverse thread....
Old Apr 21, 2005 | 03:52 PM
ChicagoX's Avatar
The bolt head is on the back side of the caliper..... clockwise in relation to you is looser.
Old Apr 21, 2005 | 05:06 PM
THX723's Avatar
G Kreuzer
A rather silly question here ...
Are you certain you're working on the correct bolt for the caliper? Believe it or not, I've seen many occurances where people have mistaken hte torque member bolt for the caliper bolts (they are very close to eachother). The torque spec. for those bolts are much higher (~2x).
Old Apr 21, 2005 | 07:47 PM
darylnj's Avatar
do you live in nj
drive over to my house i'll do it for you.
Old Apr 21, 2005 | 07:52 PM
darylnj's Avatar
don't forget the beer!
