Taking a Turn?
Old Apr 23, 2005 | 11:34 PM
rrpnow's Avatar
Taking a Turn?
What is the top speed a G sedan can take a turn at? And how sharp?
Old Apr 23, 2005 | 11:50 PM
Sandman's Avatar
Sorry, that's an impossible question to answer. Randys_G has written about going into a turn on the roval at California Speedway at 145mph, while at the same time I can't turn into my driveway at more than about 15mph without taking out the mailbox.
Old Apr 24, 2005 | 12:04 AM
GLuXuRy's Avatar
Lol
Old Apr 24, 2005 | 02:04 AM
imnohero's Avatar
The answer depends more on the driver than the car.
Velocity, acceleration, braking, turn radius, tires, pavement surface and surface changes are just some of the factors that influence the answer for every INDIVIDUAL turn. The driver must know, be able to judge (or guess) most of these factors and compensate for errors to execute a turn at the highest controllable speed.
I suppose there is a maximum theoretical speed, if you knew the right math you could calculate the maximum...but it wouldn't give you a real world answer.
Old Apr 24, 2005 | 03:49 AM
skeleton_cru's Avatar
Sedan
I can make a 90 degree turn at 140 MPH...in my TRON car.
Old Apr 24, 2005 | 10:06 AM
GeeWillikers's Avatar
Walking The Fine Line...
ROFL!
Old Apr 24, 2005 | 12:55 PM
RichK's Avatar
You have a problem then. It is obvious that your mailbox is improperly positioned at the front of your driveway.
Old Apr 25, 2005 | 10:04 PM
ComptechRSX's Avatar
Here is what u do. Aproach the turn at full speed lift off the gas but dont brake and turn the wheel as fast as you can. Then see how good you can go around the turn. Or if you got a RWD G Wait till its a rainy day turn off the Traction Control and go around a turn at a normal speed then in the middle of the turn gun the Gas and turn the wheel sharply.
Old Apr 26, 2005 | 12:13 AM
tonyplat's Avatar
Smile
Well, I've been testing all day for you, and I came up with 42.761 MPH for a turn as sharp as the one I used.
Don't listen to those people who say you need to know the specifics about the car, suspension, tires, turn, road surface, weather, driver, etc., none of those thing matter. They're just too lazy to test it for you like I did.
You're welcome.
Tony
Old Apr 26, 2005 | 06:08 PM
rrpnow's Avatar
thanks tony.. obv i wont listen to dumbasses like rsx boy... take a sharp turn, while goin fast, while its raining?
hdmark
Apr 29, 2019 04:31 PM
zcherub
Aug 30, 2015 05:04 PM
Frostbite91
Aug 20, 2015 07:20 PM
D1dphresh
Aug 7, 2015 06:10 PM
